Can change from a carburetor to fuel injection?
132,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
ANGELOTAZZ
Good day all, I like advice I'm driving the car listed above carburetor motor. I'd like to find out if it's possible to change it to a fuel injection setup but not the motor just the fueling setup.
Jan 17, 2022 at 9:53 PM
  • 110,251 POSTS
First, please understand this vehicle isn't offered in the US. However, I will try my best to help.
You need to understand that nearly everything is possible if you have the money. In this case, it won't be a simple change. First, the vehicle's control module will not recognize or operate fuel injection. Next, there will be an issue with the fuel pump. Likely, it won't provide the pressure needed.
Let me know if that helps. Also, please feel free to ask any questions you have.
Jan 18, 2022 at 6:19 AM
