Fuel Injection will not crank
150,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
WOOD IT
Will not crank. Fuel pump is working and will fire up with starter fluid. Must not be getting signal to injectors to open. The first thing that happened before it would not start, was that it died twice when I cranked it, so I drove home keeping my foot on the gas so it would not die. When I got home it idled fine. The fuel filter Is okay too.
Nov 3, 2016 at 7:29 AM
WOOD IT
If the pump is weak, could this effect the cranking?
Mar 1, 2017 at 6:39 AM
HMAC300
  • 48,601 POSTS
you mean it turns over but will not fire, try resetting security system see link. then if still not starting check fuel pressure with a gauge auto parts rent it. see link as well.
https://www.2carpros.com/articles/how-to-reset-a-security-system
