Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
MKS
Safety
Inertia Switch
driving and engine cut off has not started since?
2010 LINCOLN MKS
92,000 MILES • 3.7L • V6 • 2WD
MYMKS
MEMBER
Where is this switch located?
Feb 13, 2024 at 6:27 PM
Experienced Mechanic
I checked all of the engine wiring diagrams and Ford doesn't use the inertia switch in this model. What problem are you having?
Feb 14, 2024 at 3:24 AM
MYMKS
MEMBER
Was driving and engine cut off hasn't started since. then as a side note I had just put gas in from a gas can with aftermarket funnel.
Feb 14, 2024 at 12:19 PM
That might do it if the fuel was old/contaminated. I would try starting fluid and if that changes nothing let's check for spark.
Here is a guide and video to help us see what's going on:
https://www.2carpros.com/articles/car-not-running-advanced
and
https://youtu.be/baq_aEWNQ0Y?si=wIQTnmTJ-yJPSFjL
and
Please go over these guides and get back to us.
Feb 14, 2024 at 11:56 PM
anything?
May 11, 2024 at 3:25 AM
Add image or video
Ask a new question
Vent — No Air
