I was told the ECM was bad so I had it shipped off to be repaired and it came back saying nothing was wrong with it. Once I reinstalled the ECM car started and ran fine for a week. Now the same thing is happening but if I remove the PCM fuse and reinstall it the car will go back to normal and run fine for a little while and same thing happens. I remove the fuse again and put it back in and it will do the same. Help!
Jul 16, 2013 at 7:08 AM
