Fuel gauge not working properly
76,000 MILES • 4.2L • 6 CYL • 4WD • MANUAL
BRADLEY54
Okay, so my fuel gauge has never worked properly. when i first got the vehicle the temperature, fuel and pressure gauge did not work. i have replaced the instrument cluster (fuel, temperature speedometer, pressure and volt) still did not fix the problem. so i took it one step further and dropped the fuel tank (it was in bad shape so i replace both the fuel tank and sending unit/float.) new grounding wire from fuel tank to frame/ new grounding wire from dash to body/frame. FYI since replacing the fuel sending unit/gas tank my fuel gauge is working a little, full tank reads in-between 1/2 and 3/4 and empty (runs completely out of gas at red light with a line of cars behind me, lol) at 1/4 tank.
Any advise would be appreciated.
Apr 17, 2018 at 10:16 AM
good evening.
did you check the voltage to the sender from the dash cluster?
if not, that is where I would start.
It sounds like a wiring issue along the frame.
Apr 17, 2018 at 10:39 AM
BRADLEY54
I do not have a voltage meter. i will pick one up tomorrow and report back here with my findings.
Apr 17, 2018 at 10:41 AM
sounds like a plan.
Apr 17, 2018 at 10:55 AM
