Fuel gauge not moving?
126,000 MILES • 4 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,007 POSTS
Always stays on empty. Is there a TSB for this?
Aug 22, 2024 at 12:17 AM
  • 55,711 POSTS
Yes, a Technical Service Bulletin (TSB) related to the fuel gauge is 08-059-15. The fix is to reprogram the PCM. So you will need to go to the dealer or a shop that can do this for you.
Aug 22, 2024 at 3:59 AM
BHAMDOC1973
  • 2,007 POSTS
Can i so it with my autel or launch scanners? What would it be under? Which module?
Aug 22, 2024 at 4:19 AM
  • 55,711 POSTS
It should be under the PCM but I don't think you can conduct an update with those scanners?
Aug 23, 2024 at 12:05 AM
BHAMDOC1973
  • 2,007 POSTS
I replace the fuel pump assembly and now its showing the fuel level.
Aug 28, 2024 at 6:08 AM
  • 55,711 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Aug 29, 2024 at 1:29 AM
BHAMDOC1973
  • 2,007 POSTS
Issue starting the car, is there something that needs to be done when disconnecting the battery on these cars similar to sole Audis and VWs? While starting the steering light is on, battery, and most of them, but won't start. I removed the pump connectors and not seeing fuel, even though I am hearing the pump. I think this is a defective one, it says it fits and connectors are right but the guts if the pump does not look the same. I ordered one that looks exactly the same.
Aug 29, 2024 at 9:24 PM
  • 55,711 POSTS
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Aug 30, 2024 at 2:47 AM
