Fuel gauge malfunction
89,467 MILES • 4 CYL • AUTOMATIC
SGUTIE435
I just purchased this car used from a personal seller and my first fill up about 3 days ago my gas gage was acting up. When I would turn my car off for a few minutes my gas gauge would go from full to a quarter of a tank. Even where it tells u how many miles u have till empty it went from like 196 to 160 so both are messing up. When I start driving again it will go back up slowly. I just had my o2 sensor changed and even put a fuel treatment in before I filled. Im Still having the issue. Can u help?
Apr 15, 2016 at 12:41 AM
HMAC300
  • 48,601 POSTS
have the dash checked to see if it's bad a they are digital and can do that, but can be rebuilt, then check for a bare spot to sender causing it to do what you are saying. it's a pink/org wire it also may be a pcm problem but would require scanning by a pro.
Apr 15, 2016 at 3:16 AM
