I figured out the problem was a simple fuse when they both weren't working. It was fuse number 37 with a size 10.
Sep 19, 2022 at 4:38 PM
LOSTPANDORA
MEMBER
I believe on your little fuse thing that had something it said A/C it was further A/C.
Sep 19, 2022 at 4:40 PM
✓Experienced Mechanic
Is everything working properly now?
Sep 20, 2022 at 12:40 PM
LOSTPANDORA
MEMBER
Almost everything's good. I figured out it's the heater blowing my fuse and I believe I know how to fix it. I just haven't got to it yet. I'm leaving, I got to go to the fuse retrace the wires make sure that there's no parade in the wires and it's grounding out and check the circuits or whatever the heck they are switches to that relay the power to the fan.
Sep 21, 2022 at 12:36 PM
Sounds good. Let me know if you are able to find the cause. Also, if you have questions or if I can help in any way, let me know.
