Fuel gauge not working properly
100,457 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BRANDON LEE
The fuel gauge sometimes drops or does not read correctly and the car seems to use more gas than normal, but the miles to empty display seems to read correctly.
Oct 3, 2019 at 4:55 AM
  • 55,758 POSTS
The fact that the miles to empty is correct shows us the float is reading properly. This mean the cluster is probably bad which is common. Here is a video of a cluster replacement on a similar car with diagrams below to show you how on your car:
https://youtu.be/_HEC44xENxw
You will need to note the cars mileage and the VIN so the re-builder can reprogram the new unit for you. Check out the diagrams (below). Please let us know what happens.
Oct 4, 2019 at 7:30 AM
