Fuel gauge reads empty
67,000 MILES
JRREPAIRS
Fuel gauge still reads empty. new step motor, new fuel pump assembly.
Aug 7, 2019 at 10:31 AM
  • 110,248 POSTS
Welcome to 2CarPros.
When you replaced the fuel pump assembly, was a new fuel level sensor also installed or is that what you are referring to as the step motor?
I circled the component I am referring to in the picture below.
Aug 9, 2019 at 1:15 AM
JRREPAIRS
Complete assembly and float assembly and step motor in dash for gauge.
Aug 9, 2019 at 2:12 AM
JRREPAIRS
If sits a day wont start. small shot of either fires up fires up all day long.
Aug 9, 2019 at 2:27 AM
  • 110,248 POSTS
Welcome back:
It sounds like fuel pressure drop off. Have you checked that? Also, and this isn't related to the gauge, but have you checked the coolant temp sensor to make sure it's telling the computer the right info? If it's saying it's extremely cold or hot, the fuel mixture could be off and preventing the engine from starting.
Once it starts with starting fluid, does it run normally after? And as far as the gauge, it could be an issue with the PCM. Have you checked for corrosion or damage to the pin in the connector? Take a look at the two pics. The first shows the level sensor in the tank. The ppl wire comes direct from the PCM. Have you checked it for power? The second pic is the other end of that wire at the PCM.
Also, confirm ground for the level sensor. It is part of a splice which may have failed. You can see it in picture 1.
Aug 9, 2019 at 1:00 PM
JRREPAIRS
Scan tool gives me sensor 1low ohms not sure what is sensor .
Aug 12, 2019 at 2:36 AM
  • 110,248 POSTS
Welcome back:
Can you give me the code? It sounds like an oxygen sensor the way you described it.
Aug 12, 2019 at 11:11 AM
