Replaced fuel pump and gauge only works right when full.
Aug 5, 2020 at 10:43 AM
✓Experienced Mechanic
When you replaced the pump, was it a complete unit including the float and rheostat assembly for the fuel gauge? Does it stay on full and never move?
If it is staying on full and not reacting from that point, it's easy to snag the float when installing it causing it not to move. Take a look at pic 1. When you reinstalled the pump assembly, was the highlighted component free?
Image (Click to enlarge)
Aug 5, 2020 at 2:26 PM
MARK UNDERWOOD2
MEMBER
Thanks Joe, yes it was installed as complete unit, gauge stays on full (with full tank) , after I run about 10 gallons out of tank, it starts fluctuating wildly, fill tank back up and it stays on full.
Thanks
Aug 5, 2020 at 11:20 PM
I have to be honest. It sounds like the new level sensor (rheostat) is faulty. If you would have told me it never changed from full, I would have suspected the float got stuck during installing it. Since it does what you described, it sounds like it is bad.
Aug 6, 2020 at 4:37 PM
MARK UNDERWOOD2
MEMBER
Thanks Joe, can I just plug in another pump (not installed) and see if it changes?
Thanks,
Mark
Aug 6, 2020 at 11:45 PM
Yep, you will need to move the float up and down to see if the gauge reacts.
Let me know what you find.
Aug 7, 2020 at 4:01 PM
MARK UNDERWOOD2
MEMBER
Hey Joe, I crawled underneath truck and 1st thing I saw was a broken cable that ran from frame to filler tube, I repaired cable to no avail. What was that? For static electricity? Anyway looks like ground to fuel pump is not as easy to get to as I thought.
Any suggestions?
Thanks,
Mark
Aug 9, 2020 at 6:16 AM
Is the fuel pump working? If it is, then the ground is good. They both ground at the same point. As far as the ground, it is at the top of engine. See the attached pic.
Aug 9, 2020 at 3:33 PM
MARK UNDERWOOD2
MEMBER
Ho Joe, fuel pump is working, the gauge is not working properly. The ground for my gauge is what I'm thinking. Does gauge work off fuel pump float?
Aug 9, 2020 at 10:10 PM
That ground is on the left side of the instrument panel. See the attached pic.
Let me know if that helps.
Aug 10, 2020 at 2:23 PM
MARK UNDERWOOD2
MEMBER
Hi Joe thanks! Couldn't make out last word of ground location. I can make out " right behind left side of ?" Can't make out last word even with magnifier.
Can you please help?
Thanks,
Mark
Aug 13, 2020 at 12:29 AM
I see that. It can't be read. It says of IP which is instrument panel.
Aug 14, 2020 at 5:16 AM
MARK UNDERWOOD2
MEMBER
Hi Mr Joe! Thanks again for info.
I found grounds as diagram shows. The ground to rear of right cylinder head was broken in half. Can I ground this wire elsewhere? Exhaust manifold? Intake manifold?
Thanks!
Mark
Aug 17, 2020 at 3:30 AM
Mark,
Don't ground it on the exhaust manifold. It will burn off. Just find a good ground place on the engine where it isn't near anything too hot. You could even ground it to the body of the vehicle.
Aug 17, 2020 at 7:18 AM
MARK UNDERWOOD2
MEMBER
Hi Joe, I replaced and cleaned 2 grounds (actually it was just a frame to body to engine ground) that were under hood and now gas gauge just stays pegged out. Any ideas? Suggestions?
Thanks,
Mark
Aug 18, 2020 at 1:45 AM
If it was a body ground, I'm surprised it changed anything. Did you locate the ground under the instrument panel?
If it is pegged, the only other thing I can think of is the float is stuck or the rheostat is no good.
Aug 18, 2020 at 11:32 AM
MARK UNDERWOOD2
MEMBER
Hi Joe, yes I redid ground wires under instrument panel and body ground on left side of engine (body to ground). With still pegged out fuel gauge. Is there anyway to check grounds that I redid? I want to check out all possibilities before I pull truck bed.
Thanks,
Mark
Aug 19, 2020 at 10:58 PM
Mark,
The only thing you can do is check for continuity to ground from the opposite end of the wires that you repaired. Is there any chance you could have gotten the float stuck when you replaced the fuel pump? If this wasn't an issue before the pump replacement, then I suspect that either the float is stuck, the sender rheostat is bad on the new unit, or you have a short to power. If you disconnect the connection at the pump, does the gauge drop to empty?
Aug 20, 2020 at 3:06 PM
MARK UNDERWOOD2
MEMBER
Hi Joe thank you for your info. You helped me greatly by pointing out the grounds and such.
I have decided against dropping the tank for now.
For other questions do I need to go back to main page or ask here?
Thanks,
Mark
Aug 29, 2020 at 9:47 PM
Mark,
If the question is related, I would be happy to help. If it is on different topic, I ask that you start a new thread. We try to keep things specific to one issue per thread. I hope you understand.
