Fuel gauge not working
2001 CHEVROLET TAHOE
197,574 MILES • V8 • 2WD • AUTOMATIC
KRISC1987
I just replaced my fuel pump had to rewire a new plug and now my gas gauge does not work at all. I pulled it out made sure that I did not bend my float or anything. It is just reading empty when I have over 3/4 full tank of gas.
Nov 13, 2018 at 3:40 AM
Good afternoon.
Did you have to replace the square plug and make it a flat plug?
How did you connect the wires? Did you solder and shrink wrap the wires or just use butt connectors?
Did you match the colors?
Can you post a picture of what you see?
Nov 13, 2018 at 3:47 AM
KRISC1987
I used butt connectors and I had to retrace my steps found that the power wire was corroded past the second plug so I bridged in a new section of wire and now it works just fine. I just finished putting everything back together.
Nov 13, 2018 at 8:40 AM
Good find. Glad you got it fixed.
Nov 13, 2018 at 8:44 AM
