Fuel gauge not working properly
300,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
DANIELN42
Fuel gauge works but it is not accurate. how can i fix this the cheapest way possible?
Jul 15, 2019 at 5:41 AM
Good afternoon,
You will need to replace the sender unit in the tank.
I posted one from rock auto. It is not cheap. The only other way is a used one which I never recommend.
CAUTION: Do not smoke or work near an open flame when working on the fuel pump.
1. REMOVE REAR SEAT CUSHION
2. REMOVE FLOOR SERVICE HOLE COVER
a. Take out the floor carpet.
b. Remove the service hole cover.
HINT: At the time of installation, please see the items. Check for fuel leakage.
3. DISCONNECT FUEL PUMP & SENDER GAUGE CONNECTOR
4. REMOVE NO.1 FUEL TANK PROTECTOR
Remove the 2 bolts and No.1 fuel tank protector.
Torque: 4 N.m (40 kgf.cm, 35 in.lbf)
5. DISCONNECT FUEL TUBE (FUEL TUBE CONNECTOR)
CAUTION:
- Perform disconnecting and connecting operations of the fuel tube connector (quick type) after observing the precautions.
- As there is retained pressure in the fuel pipe line, prevent it from splashing inside the vehicle compartment.
6. REMOVE FUEL PUMP ASSEMBLY FROM FUEL TANK
a. Remove the 6 bolts and fuel tank vent tube set plate.
b. Pull out the fuel pump assembly.
c. Remove the gasket from the pump assembly.
NOTE:
- Do not damage the fuel pump filter.
- Be careful that the arm of the sender gauge should not bent.
HINT: At the time of installation, please see the items. Install a new gasket to the pump assembly.
Jul 15, 2019 at 6:00 AM
