Car listed above SE model fuel gas cap won't open when I click on the button. Not even a single noise. Anybody?
Oct 16, 2021 at 5:35 AM
SQM
✓Experienced Mechanic
So, when you press the button to open the fuel door. Does it make any noise?
This issue could be due to a bad switch or the actuator that opens the door.
I have attached the replacement instructions as well as testing procedures for those components.
I click on the button and nothing not even a noise or click.
Oct 16, 2021 at 8:37 AM
SQM
You will need to see if there is any power to the switch and also if the actuator is getting power when the button is pressed. This will tell you if the switch or the actuator is bad.
Oct 16, 2021 at 9:20 AM
KOUBEAR
MEMBER
Okay, and how do I do that?
Oct 16, 2021 at 9:51 AM
SQM
You will have to remove the switch or access the back of the switch and use a voltmeter to check for power. Same thing can be done for the actuator.
Look at first response you will find the instructions on how to replace and test those components.
Thanks.
Oct 16, 2021 at 10:25 AM
Good morning,
Check your owner's manual. In there it should tell you the location of the manual pull cord to open the fuel door.
You will need to remove the trim panel in the trunk to access the cord.
Oct 16, 2021 at 9:06 PM
KOUBEAR
MEMBER
Thanks, but I already know about the manual pull cord. I'm trying to figure out why the release buttons won't open it.
Oct 17, 2021 at 2:22 AM
SQM
Removing those panels can be done using simple hand tools.
If you are stuck in a specific spot, please let me know, and I will see if I can provide any insight. Thank you.
Oct 17, 2021 at 8:21 AM
KOUBEAR
MEMBER
Having no knowledge about cars it's very hard. I look at my spring and latch bit I don't know if it is good or not, hahah.
Oct 17, 2021 at 9:07 AM
Did the door pop open when you pulled the manual cord?
That will tell you if the spring is good on the door.
Oct 17, 2021 at 9:13 AM
SQM
That is a good point by Roy. If it pops open, then the issue is the figure out if the actuator is getting power to it. This can be checked by a multimeter by reading the output at the connector that goes to the actuator.
This might sound challenging but can be done.
