Fuel gauge not working
1975 CHEVROLET CORVETTE
55,000 MILES • V8 • 2WD • AUTOMATIC
ED75VETTE
Fuel gauge stuck on full, would stick once in a while now it is stuck for good.
Jul 10, 2018 at 9:33 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Sounds like you are having a problem with the Fuel Sending Unit. It's located inside the tank and acts as a Potentiometer to gauge the fuel level. You will probably be able to remove it by just jacking up/lifting rear of car off the ground to gain access. It should be located on the bottom of tank so best to remove when tank is empty. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Jul 11, 2018 at 10:46 AM
