Fuel Gauge
155,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
SFCTRIPLETT57
  • 184 POSTS
The fuel gauge is not working on my 1987 Toyota Pickup?
Apr 17, 2021 at 11:43 AM
  • 110,248 POSTS
Because of the model year, I have very limited wiring schematics. However, there is a sending unit that mounts to the top of the fuel tank. First, check to see if it is still attached. See pic 1. Note: The pic shows a 4Runner, but the design is the same for both vehicles.
Basically, the sending unit in the tank is simply a rheostat that changes voltage signal based on fuel level. So, first check to see if it is connected. If it is, confirm power and ground. Make sure there are no broken wires and confirm the connection is clean, tight, and free of corrosion.
If you look at pics 2 and 3, that is what I was able to find as far as a wiring schematic. Here is a link you may find helpful:
I hope this helps. Let me know if you have other questions.
Apr 25, 2021 at 12:28 PM
