Good afternoon.
Is this fuel injected or does it have a carburetor?
If it has a carburetor, it is in the inlet side of the carburetor. Remove the line and then the big fitting. It will be right behind there with a spring in front of it.
If it is fuel injected, it is back by the fuel tank in the fuel feed line. You will need a 5/8 wrench and a 3/4 wrench to remove it.
May 5, 2018 at 6:53 AM
