Hello, I need help. I need to replace my fuel filter on my car listed above GM Echotec 2.2L. I have been looking for a video, with no luck.
Dec 16, 2018 at 1:15 AM
DANNY L
✓Experienced Mechanic
Hello, I am Danny.
Unfortunately your fuel filter is a part of the fuel pump assembly.That is located inside the fuel tank making it only accessible when the fuel pump assembly is replaced. I have attached a picture of its location. Hope this helps and thanks for using 2Carpros.
Danny-
Image (Click to enlarge)
Dec 16, 2018 at 5:18 AM
MANUEL E CASTRO
MEMBER
are you saying that the fuel filter is part of the fuel pump? Because in the image you sent me I do not see the fuel filter. Can I drop the tank and replace the fuel filter without removing the pump?
Dec 16, 2018 at 8:45 AM
MANUEL E CASTRO
MEMBER
2005 Saturn Vue. I found this under my car, do you know what it is?
Dec 16, 2018 at 9:03 AM
DANNY L
Hello again,
That is called the evaporative canister.That is used to store gasoline fumes from the fuel tank and then sent back through lines to the engine to be re-burnt to help reduce emissions/pollution.Hope this helps and thanks again for using 2CarPros.
Danny-
