Where is the fuel filter and MAF Sensor located?
62,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
FPIV
I am unable to locate fuel filter and MAF Sensor locations, for maintenance. Thank you Respectfully.
Jan 16, 2024 at 10:55 AM
  • 110,246 POSTS
The fuel filter is in the fuel tank along with the fuel pump. See pics (1-3) below.
The vehicle doesn't have a mass air flow sensor (MAF). In its place is a MAP (manifold absolute pressure sensor). Pics 4 and 5 are the directions.
I'm not sure if you have issues with these components, but if not, I would leave it alone. These vehicles are so sensitive to anything that isn't an OEM part. You may end up causing issues. However, that is your choice. LOL
Note: To access the MAP sensor, you will need to remove the charge air tube. Starting at pic 6 are the directions for removing it.
Jan 16, 2024 at 11:51 AM
FPIV
Thank you so very much, your assistance was invaluable to me.
Jan 17, 2024 at 1:21 AM
  • 110,246 POSTS
You are very welcome. I'm glad to know it helped. Let me know if you have other questions or if I can help.
joe
Jan 17, 2024 at 9:32 AM
