Fuel filter location
23,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
ASULESKE
Fuel filter for my 4USBT33483LS426759.
Jan 12, 2020 at 1:17 AM
The fuel filter for this vehicle is in the fuel tank and part of the fuel pump assembly. See the attachments. The only time it requires changing is when the fuel pump is removed or there is another issue that has you take it out.
Let me know if you have other questions about this. Thanks
Jan 12, 2020 at 7:24 AM
ASULESKE
Manual refers to an in-line filter. Where is this? Thanks.
Jan 13, 2020 at 1:05 AM
I have checked Alldata and Mitchell and they do not show an inline filter.
I highlighted the vehicle selected vehicle just below. Let me know if this is not your vehicle. However, I would suggest just following the fuel lines from the tank to the engine and you will run into a filter if it is there.
Lastly, can you get a picture of the manual for me where it is talking about the filter. Just be careful with them because they normally put all all different engines and models into manuals to try and save paper.
Jan 13, 2020 at 5:51 AM
