Engine not running?
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
SAM JONES2
Clogged and successfully replaced. Now backfires. Stuck on side of road. What is most likely cause and easiest fix?
Jul 26, 2020 at 7:41 AM
Good evening,
Why did you change it?
https://www.2carpros.com/articles/engine-backfires-while-running
Can you hear the fuel pump run with the key on?
When you crank it, does the tachometer move up a little showing RPM? That will tell me if the crank sensor is sending a signal.
Is the check engine light on? If so, do you know the codes?
Apr 9, 2021 at 7:23 AM
