Where is the Fuel filter located?
111,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
DENNIS HILL
Where is it located exactly the fuel filter?
Dec 12, 2023 at 12:39 PM
CANNON1349
  • 861 POSTS
Hello and thanks for your question,
The fuel filter is made into the fuel pump assembly in the gas tank. At least this is what I am finding on my end. You will need to drop the gas tank and remove the fuel pump assembly to remove the paper filter attached. At that point I would just replace the pump with a new assembly. Let us know if you want to move forward on replacement instructions, it can be a bit involved.
Thanks for using 2Carpros!
William
Dec 13, 2023 at 12:04 AM
