Where is the fuel filter located?
143,000 MILES • 2.7L • V6 • 2WD • AUTOMATIC
RACER8X
I am replacing the fuel filter on the car listed above LX model. I need to know where the fuel filter is located.
Feb 28, 2022 at 4:55 AM
SQM
  • 6,383 POSTS
This vehicle does not have an inline fuel filter.
The filter is mounted on the fuel pump, located in the fuel tank.
It can be accessed through the service port that is located in the trunk. You will see the access port after removing the carpet.
I have attached diagrams below for your reference.
Feb 28, 2022 at 5:08 AM
RACER8X
Okay. Can I replace the fuel filter or do I need to replace the whole pump?
Feb 28, 2022 at 5:11 AM
RACER8X
My car has a stutter when I hit an incline and when I try to give it gas it won't go.
Feb 28, 2022 at 5:15 AM
SQM
  • 6,383 POSTS
Yes, you can just replace the filter that is mounted on the pump.
Does the shuttering only happen in incline?
How much fuel did you have when this happened?
Feb 28, 2022 at 5:47 AM
