Engine will not stay running
150,000 MILES • 5.3L • V8 • 2WD
DIANNA JACKSON
Seems like it’s starving for gas, engine shuts off after idling for about 10 minutes. Could it be a possible fuel filter issue?
Nov 7, 2021 at 3:18 AM
  • 110,248 POSTS
Does it start right back up for you? Also, yes it could be a fuel-related issue or an ignition problem.
If it doesn't start right back up, it could be a faulty crankshaft position sensor. When they begin to fail, heat has an adverse effect on them. Once they cool, the engine will start. That's why I asked if it starts right back up.
I am including two links. The first one explains how to test fuel pressure and the second explains the symptoms of a faulty crankshaft sensor. Take a look through the sensor symptoms. If they don't mirror what you experience, then check the pressure.
Let me know your thoughts or if you have any questions.
Nov 7, 2021 at 12:23 PM
