Fuel filter location and replacement instructions
76,000 MILES
MIKE RAMEY
Where is located on the vehicle?
Feb 11, 2019 at 12:08 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Shown on the diagram below the fuel pump is located in the gas tank.
Feb 11, 2019 at 1:29 AM
MIKE RAMEY
Thank you for the information. so there is no inline fuel filter?
Feb 11, 2019 at 9:37 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome and no there is not an inline fuel filter. The older trucks had one under the manifold pipes but these trucks only have one as part of the pump assembly.
Feb 12, 2019 at 12:00 AM
DERIDDER
where is the fuel filter?
Mar 6, 2021 at 2:31 AM (Merged)
  • 55,658 POSTS
The fuel filter is located on the frame rail on the drivers side right about where the passages seat is. Here is a video of the job being done.
https://youtu.be/OPbnlCpRans
Please let us know if you need anything else to get the problem fixed. NOTE Fuel filter on a 4 cylinder 2.4l 2wd Tacoma is located on the driver's side portion of the engine block under the intake manifold difficult to reach.
JACOB.M.HOUSE
where is the fuel filter located on a 2002 toyota tacoma with a 2.7 liter
  • 75,988 POSTS
Its in the fuel tank below the fuel pump. However, if you have the 2RZ-FE engine then you have a filter under the intake manifold as well.
The other engines only have one in the tank. I included info on this filter as well below. Please let us know if you have other questions. Thanks
JDIZZ107978
Can't find fuel filter. Please send images. Thanks
DANNY L
  • 5,648 POSTS
Hello,I'm Danny.
Here is a basic fuel filter tutorial for you to view for filter replacement:
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
I've attached the location and picture steps on how to replace the filter for your truck below.Hope this helps and thanks for using 2CarPros.
TINKERDALE
Engine Performance problem
1995 Toyota Tacoma Two Wheel Drive Manual 147K miles
I let the air filter get too dirty on my truck and then added new one and injector cleaner..felt something pop loose and the acceleration felt like a new truck. Will changing the fuel filter help? Can't find anything on Fuel filter in my book? Is this the same as the pcv valve that I replaced bout 2years ago? Where is the Fuel filter located?
Another question. One of my fly wheels made an awful noise, so I took a paintbrush and put heavy grease on them all..made sure I missed belts ect. Do I need to replace the wheel? Did this bout the same time as the afore mentioned fuel injector treatment.
Thx/ give ya $5 a question!
tinkerdale in Florida
Mar 6, 2021 at 2:32 AM (Merged)
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9428e278f1="tinkerdale"]Engine Performance problem
tinkerdale in Florida[/quote:9428e278f1]
No the PCV Valve and the Fuel Filter are not the same. The fuel filter I believe on you vehicle is mounted on the inner frame rail under the vehicle in the area of the driver seat. Wouldn't hurt to change if hasn't been change in while.
I take it when you speak of the fly wheel you mean pulleys. The pulley(s) most likely to have been causing the noise is either the Idler Pulley or the Tensioner Pulley. And yes you will need to replace one or both of them. If they are making noise you can with the vehicle off spray the center bolt of one of the pulleys then start the vehicle if noise is gone for short period of time then the pulley is bad. If noise is still present then turn vehicle off and spray center bolt of the other pulley and start vehicle. If noise is gone replace pulley.
Depending on the engine it may only have one of the pulley mentioned above.
RUNNER17_1
  • 5 POSTS
I just changed my fuel filter on a 95 Toyota pickup if you look on the passenger side in front just right above the oil filter its in a tight place so you have to look really in there if its not there look back by the gas tank on the frame but if its like my truck its right above the oil filter
DANNY77762
the fuel filter is located up under the intake manifold, if you have big hands i wouldnt attempt to change it. you need 2 hands to work with it. good luck
