fuel filter location
150,000 MILES • 6 CYL
TAMMY RISNER
I need to know where it is located.
Feb 15, 2017 at 3:54 AM
HMAC300
  • 48,601 POSTS
check by the gas tank along frame rail on drivers' side is where the fuel filter is normally.
Feb 15, 2017 at 3:57 AM
  • 55,749 POSTS
Here is a guide to let you know what you are in for when replacing it.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Please let us know happens so it will help others.
Best, Ken
Feb 18, 2017 at 9:02 AM
KRISMERK913
Where is the fuel filter on a 2000 Pontiac Bonneville located at?
Jun 1, 2019 at 9:44 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Under vehicle, driver side, below seating area, front of fuel tank, mounted on chassis in fuel line
KPAX
where is the fuel filter located on a 98 Bonneville, and do I need to shut off the fuel pressure fuse, and if so, where is it located?
BLACKOP555
  • 10,386 POSTS
it would be good to drain the fuel pressure before, you can start the car then pull the fuel pump fuse.
the fuel filter should be about midway from tank to the engine, follow the fuel llines.
SUSMAN28888
  • 62 POSTS
HI,
were is the fuel filter located on a 2000 bonneville.. ponitac, 69 k..
thanks in advance,
joe
PS; if my car has one, how hard is it to replace?
Jun 1, 2019 at 9:45 AM (Merged)
SERVICE WRITER
  • 9,123 POSTS
Yes it does. I would change it every 30-35,000 miles.
https://images.2carpros.com/forum/automotive_pictures/30961_fuel_filter_1.jpg
There is a plastic disconnect at one side. and threads at the other. I'm not sure how much of a pita is without a lift, but you'll need a little room to work.
GBELLAND
I cannot find the fuel filter on my pontiac bonneville ssei, 2002, with supercharger. I am trying to replace the old one.
MFERK77
It may be right directly behind the gas tank. most vehicles have them there.if not look all around the tank.
LVDANGEL4
I know on my Bonneville it is on the passenger side in front of the rear tire. Good luck!
