Fuel filter location?
275,000 MILES • 3.8L • 6 CYL • AUTOMATIC
JER20ME
Where is the fuel filter located in my car? I have looked in all of these suggested areas and do not see it. Is it inside the fuel tank? If yes, how do I access it to change the filter myself?
Jul 17, 2019 at 7:11 AM
Good evening,
The filter is located just in front of the fuel tank under the car. This guide will help walk you through the repair with diagrams below to show you how on your car
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jul 17, 2019 at 7:19 AM
DANIEL LAWRENCE
6 cyl Two Wheel Drive Automatic 50000 miles
I cannot find the fuel filter, where is it?
Oct 14, 2020 at 5:39 AM (Merged)
  • 75,988 POSTS
The fuel filter is located on the fuel feed pipe, between the fuel pump and the fuel rail under the car toward the fuel tank. You will need to raise the car in the air to get to it.
Here is a guide that should help.
CISCODAKID
can i replace fuel filter without dropping gas tank?
BRIAN 1
  • 1,030 POSTS
sorry but you have to drop the tank. it's weird because on the impalas they have an access cover in the trunk to pull the fuel pump,but the grand prix does not. my point is there both W bodys,bothe the same car. strange?
NIKON 2099
2002 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
how do i depressurize the fuel lines so ican change the fuel filter
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable to prevent possible discharge of fuel if an accidental attempt is made to start the engine.
Loosen the fuel filler cap to relieve tank pressure.
This procedure calls for a fuel pressure test gauge with a line equipped with a fitting to connect to the to the fuel pressure test connection and another hose to discharge into an approved gasoline container. Wrap a shop towel around the pressure test fitting connection while connecting gauge to avoid spillage.
Install the bleed hose into an approved container and open the valve to bleed fuel system pressure. The fuel connections are now safe for servicing.
Drain any fuel remaining in the gauge into an approved container.
Reconnect the negative battery cable unless additional service work is being performed.
RANDELLM
Know my filter needs changed but cant find it. where is it
Oct 14, 2020 at 5:40 AM (Merged)
JDL
  • 16,098 POSTS
Hello, my info shows, under the vehicle, rear of gas tank. You may have to safely raise and support the vehicle to get a look at it?
UNLUCKY#1
Was wondering where the fuel filter would be and how often it should b changed?
BLUELIGHTNIN6
  • 16,542 POSTS
It is under vehicle, center, below trunk area, rear of fuel tank, mounted in fuel line and Pontiac does not list a mileage interval to replace the fuel filter. If you suspect low fuel pressure than the fuel filter is a good place to start diagnostics.
JUDY0127
I try to start my engine, but it is not firing. It is turning over.
HMAC300
  • 48,601 POSTS
fuel filter is by the gas tankon side of frame. But check for codes, cross A&B at aldl count the flashes to see if there are any other codes besides code 12. Also check fuel pressure, if port fuel it should be41-47 psi if TBI 9-11
SANDYPED
Engine Mechanical problem
1981 Pontiac Grand Prix V8 Two Wheel Drive Automatic
my car won't turn over. could it need just a new fuel filter? If so where is it? Is it right up against the carb or under the car
JDL
  • 16,098 POSTS
hi, thanks for the donation, my info shows it is in the fuel line, next to carb. Are you saying it cranks good but won't start, or it won't even crank?
https://images.2carpros.com/forum/automotive_pictures/170934_81_pontiac_fuel_filter_1.jpg
https://images.2carpros.com/forum/automotive_pictures/170934_fuel_filter_picture_1.jpg
SANDYPED
Yes it does crank, it just is not getting fuel. can't even smell it.
JDL
  • 16,098 POSTS
You may be headed in the right direction. If you open the choke and look down throttle-bore while working the accelerator, can you see gas squirt? If not, possible problem with fuel pump-- filter--maybe you need to put a carb kit in it.
SANDYPED
Nope, no squirting anything. Except for my patience...whatever that means...LOL
Anyway, I am thinking do the pump first then if that doesn't fix it THEN the carb. Correct?
You guys are great!! What a great service you offer!
JDL
  • 16,098 POSTS
We try to help. You might take the fuel supply line loose from the carb, aim into proper container, Have helper crank engine, see if any gas comes out. I can usually get a rubber fuel line over the flare on a steel line. If no gas comes out, I'd have to check mechanical fuel pump. You might smell of crankcase oil dipstick, if smells like gas, I'd definitely change the fuel pump. Oil and filter, also.
DONWAYNE
I have a 1994 Pontiac Grand Prix and I cannot find the fuel filter-can you tell me where it is? Thanks.
HARMAN
it might not have one my 2006 pontiac grand prix dosent have one either
LSUSSEL
  • 252 POSTS
check on the passangers side, almost under where the passangers seat is, its a pain in the but to get to, you must know what your doing.
