Fuel filter location
150,000 MILES • 6 CYL • AUTOMATIC
STARLORD1976
  • 173 POSTS
Where is the fuel filter located and can I just change it without changing fuel pump?
Jul 16, 2020 at 8:51 AM
Your filter is part of the fuel pump assembly in the tank. You do not need to change this unless you have to remove the pump for another reason.
I attached some info that explains this. Let me now if you have other questions. Thanks
Jul 16, 2020 at 9:00 AM
STARLORD1976
  • 173 POSTS
Whenever I drive my car and as I have my foot on the gas the car will stall and not do anything a couple of times and then will start going. Is this a fuel problem or a transmission problem. Whenever it does do it the rpm will go to about 2 but know higher?
Jul 16, 2020 at 9:14 AM
This could be a fuel issue. It is most likely not a transmission issue. However, we need to test the fuel pressure to try and confirm this.
Once we are able to test the fuel pressure we need to start a new post with this specific issue. The reason is, others that have this issue will not find it under a post of a fuel filter. We want to not only assist those that ask questions but make it easy for those that have similar issues to find what fixed your issue. Here is a link to a new question. Let's test the fuel pressure and post the results on a new question and we will get back to you. Thanks
Jul 16, 2020 at 10:49 AM
