Fuel filter location?
188,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
TIMOTHY CARTER2
Where is the fuel filter?
Does it have one other than the one in the tank?
Nov 21, 2019 at 6:21 AM
Good afternoon.
The filter is at the fuel pump. It is the only one listed. I attached a picture of the location of the filter for you to view. Check out the diagrams (Below). Please let us know what happens.
Nov 21, 2019 at 6:39 AM
FIRECHIEF
1999 Dodge Ram Where is it located. Thanks
Aug 27, 2020 at 5:05 AM (Merged)
  • 75,988 POSTS
Check at the fuel tank where the fuel pump module-its right beside the pressure regulator.
GUTTERMAN67
can not find fuel filter on frame
JDL
  • 16,098 POSTS
Welcome to the forum, the fuel pressure regulator has an internal filter, the regulator is on top of the fuel pump module. There is no separate fuel filter, that I know about.
FINALLYFREE43
Where is the fuel filter located on a 1999 Dodge Ram 1500, 4x4, 5.2 l
CARADIODOC
  • 34,414 POSTS
What's the symptom? Except for diesels, you will never solve a running problem on a Chrysler product by replacing the fuel filter.
PAINTER969
  • 8 POSTS
i replaced the fuel pump in my 2001 at the adviace of a friend.after replacing the $130 fuel pump i realized all i needed was a tune up.replaced plugs, wires,cap and rotor button ran great after and now i have an extra fuel pump that i dont need.
MOTANUL79
i can't not find the gas filter!
Aug 27, 2020 at 5:06 AM (Merged)
BLACKOP555
  • 10,386 POSTS
should be where the cab and the bed meet in that general location. follow the fuel lines from the tank up to the engine, you will find it that way.
there is also one on the fuel pump.
PETECT
  • 8 POSTS
I was told there is no filter under the truck.Only on the pump
BLACKOP555
  • 10,386 POSTS
also there may be one in the fuel pressure regulator.
strange theres no filter under the truck!.
SHAN1922
I staled in the middle of the inter section. It turns over but when i give it gas it dies. i had someone look at it and they said it was a fuel problem. the fuel isnt getting to what ever part it needs to run. They said to try to replace the fuel filter then next thing would be fuel pump... does that sound right? how would i change that since the filter is under the pump>?
JDL
  • 16,098 POSTS
Hello, I'd use a gage and double-check fuel pressure. I'd also check for good B+ and ground at the pump. Check for codes. If you need to get at the pump, look and see if you can reach anything, if not, lift the bed or drop the tank.
JARED13SBS
How do you change the fuel filter from inside the gas tank?
JDL
  • 16,098 POSTS
Hi, not sure which filter your talking about? If strainer that is on the end of fuel pump? You'll have to drop the gas tank and remove fuel pump assembly.
There is a regulator/fuel filter on top of the fuel pump assembly, not in the tank. Don't know if you can reach without dropping the tank?
MCBUTLER
how do i change a fuel filter on a 98 dodge ram pickup 1500 series 6 cyl engine
  • 55,694 POSTS
The fuel filter is located at the top of the fuel tank. Here are some diagrams of where the filter is located in the tank. (below)
It is with the pressure regulator.
Cheers, Ken
JELLIS85
could someone tell me were the fuel filter is located. Motor is a 318. Thanks
MERLIN2021
  • 17,250 POSTS
sing a twisting motion pull fuel filter/pressure regulator from the rubber grommet on the fuel pump module, ensure it's not pulled more then 3 inches out or damage to the pressure regulator can occur! Dodge recomends the tank be removed to service the filter/regulator! It's on top of the gas tank!
https://images.2carpros.com/forum/automotive_pictures/62217_Gas_Tank_1.jpg
BUD0529
Is the fuel pump and filter located on top of the gas tank on a 1998 dodge ram 2500 reg cab (5.9 360)?
SERVICE WRITER
  • 9,123 POSTS
YEah, nice place huh? You'll need to drop the tank to get the pump out. The filter/regualtor assy is on top on the module fuel pump module.
https://images.2carpros.com/forum/automotive_pictures/30961_zfilt_1.jpg
STEVE MLADY
where is the fuel filter on a 318 emgine located
CH112063
  • 1,320 POSTS
The fuel filter is in line on the pressure side of the fuel system. It is near the fuel tank, mounted on the frame, you can follow the larger fuel line back from the engine, or out of the fuel tank to locate it. On every 98 318 injected truck, you must de-pressurixe the system before replacing any component in the system and use care for your eyes. I always recommend disconnecting the negative battery cable for safety. ok Joe
JSWAIN
  • 24 POSTS
I thought the fuel filter on those trucks was just a sock, or mesh screen, inside the gas tank around the fuel pump?
CH112063
  • 1,320 POSTS
Hello, every tank does have an initial screen to protect the pump internal parts, a screen, or sock as it is called. But unless your truck has something different, the filter is in the 5/16ths pressure line(8mm) a couple yards down toward the engine. It is a 36,000 mile change recommended. Never saw one without one because of the cost of injector and engine damage under warranty. OK It has the fittings you use a push in tool(pliers) for. OK Steve. Maybe they ran out of them and changed it. New to me. Put one on friday. Good truck. If you haven,t had pump(fuel) problems good. There were some problems with the in tank pumps, but I only see the bad ones so I would not be too concerned.
MJARNOLD
where is the fuel filter located? I would like to change
I have been told that this could be my problem.Truck runs welll and at times is will run very rough .
When i rep it up it clears.
Thanks
  • 75,988 POSTS
The fuel filter/fuel pressure regulator is located on top of fuel pump module.
https://images.2carpros.com/forum/automotive_pictures/12900_fuelfilter_1.gif
