What can I do to improve poor fuel efficiency?
111,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
VIJAY SONI
  • 11 POSTS
I am getting 12-13 MPG fuel efficiency from my car on average. This seems low to me. Can I do something to improve it?
Aug 20, 2022 at 7:35 AM
SQM
  • 6,383 POSTS
There could be a number of reasons why you are getting poor fuel mileage.
From basic engine tune up to emission or other issues.
Are you experiencing any drivability issues?
Is the check engine light on? If so scanning and retrieving the codes can help with the diagnostics.
Many times, doing a tune up can improve overall efficiency significantly. Like replacing the air filter, changing out the spark plugs, cleaning the throttle body and mass airflow sensor etc.
Take a look at this helpful guide:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Let me know of any questions.
Aug 20, 2022 at 9:10 AM
VIJAY SONI
  • 11 POSTS
My car does not seem to have any drivability issue and no codes upon scanning. But as I said mpg is only 12-13. I tried adding those cheap additives available for about $10 at AutoZone, in gasoline which are supposed to clean the injection system but no difference. Should I inspect the spark plugs next? or just change them to see if it helps.
Aug 24, 2022 at 8:37 AM
SQM
  • 6,383 POSTS
Follow the guide and check the typical items and take the suggested steps.
If the plugs are worn, then replacement would be recommended. Be sure to check the air filter as well as the mass air flow sensor.
Aug 24, 2022 at 2:57 PM
VIJAY SONI
  • 11 POSTS
How can I change the spark plugs myself on this car? I went to a repair shop to get quotes on replacing just spark plugs. He was asking $450+ which I cannot afford.
Aug 27, 2022 at 9:15 AM
SQM
  • 6,383 POSTS
See attached for the spark plug replacement procedure.
Keep in mind that you will also need to check the air filter and replace it if necessary, also cleaning out the throttle body is also recommended.
https://www.2carpros.com/articles/how-to-replace-a-car-air-filter
See diagrams below.
Aug 28, 2022 at 8:19 AM
