fuel cutoff relay
317,600 MILES • 2.0L • 4 CYL • FWD • MANUAL
BILLTHIB
I had to replace the relay, so the car starts and runs well. I have been told that the relay malfunctions due to getting hot. If this is true, can it be re-used after it cools off?
Aug 20, 2017 at 1:42 PM
  • 55,766 POSTS
The relay gets hot because the fuel pump is going out and it is pulling too much amperage. You should replace the pump and the relay.
Cheers, Ken
Aug 21, 2017 at 10:52 AM
BILLTHIB
Thanks for your response. I did have the fuel pump replaced a few years ago. Any idea how long it may take for the relay to overheat? Also, how often would this problem occur?
Aug 23, 2017 at 12:14 PM
  • 55,766 POSTS
The more resistance the more rapidly it will heat up.
Aug 24, 2017 at 3:21 AM
