Fuel consumption
105,000 MILES • 2.4L • 4 CYL • AUTOMATIC
USAMA AHMED
Hello, please i have the car listed above that has been having black smoke. after changing a lot of sensors it still did not help. the black smoke is still there. we decided to fix a borrowed brain box for test of 2 days which i did and it stopped. am yet to change the brain box.. my question is, does black smoke consumes a lot of fuel?
Jul 7, 2020 at 4:37 PM
Yes. Basically black smoke is unburned fuel that is going through the exhaust. It doesn't necessarily mean that it is using more fuel but it is just not burning it all in the combustion chamber.
https://www.2carpros.com/articles/engine-black-smoke
If you changed the control module and it fixed the issue then clearly that was the issue and more then likely it was causing the engine to be over fueled or an insufficient spark.
Let me know if you have questions. Thanks
Jul 8, 2020 at 8:49 AM
USAMA AHMED
I will definitely update you as soon as i change the brain box.
Jul 8, 2020 at 10:33 AM
Sounds great. However, we need to keep all communication on this site so that others can see what you do if they have the same issue.
Jul 8, 2020 at 1:50 PM
USAMA AHMED
Okay, thanks.
Jul 8, 2020 at 7:56 PM
You are welcome. Let us know what happens. We will wait to hear back from you. Thanks
Jul 9, 2020 at 12:05 PM
USAMA AHMED
Okay.
Jul 9, 2020 at 7:31 PM
