Fuel code keeps coming back after i turn the car off and on?
2014 BMW X5
157,009 MILES • 6 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
MEMBER
If i delete the codes i get the 2 in the picture. Some readings for engine off and then on.
Images (Click to enlarge)
Jan 1, 2025 at 2:02 AM
✓Experienced Mechanic
The 165011 and 165013 diagnostic trouble codes (DTCs) for a 2014 BMW X5 typically refer to issues related to the crankshaft position sensor and valvetronic system. How does the engine seem to run, can you unload a video? Here is the location of the crankshaft sensor which I would replace and then clear the codes. Check out the images (below). Let us know what you find.
