Engine shuts off when warm
230,000 MILES • 3.5L • V6 • 2WD
DARRELL COBB
Run for a minute drive it then once it warms up shuts off. cleaned the fuel injectors and ran fine for a day no problem. then got in it drive it shut off again. it crank back and idle fine one in gear goes shuts off.
Dec 3, 2019 at 11:37 AM
  • 110,251 POSTS
When it stalls, does it start right back up? Has the check engine light come on?
If it stalls when warm, it sounds like a crankshaft position sensor. Take a look at this link and see if it mirrors what you experience.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Dec 3, 2019 at 12:13 PM
