1994 Chrysler LHS car cut off
MARY BROWN
  • 1994 CHRYSLER LHS
Engine Mechanical problem
1994 Chrysler LHS 6 cyl Front Wheel Drive Automatic
temp switch goes over half way the car shut down don"t start back up until guage goes back down it may take an hour to cool off. Changed temp switch did the same thing.
Thursday, September 10th, 2009 AT 7:42 PM
  • 109,885 POSTS
Has the check engine light come on? Also, have you checked to see if you are getting spark and fuel to the engine when this happens?
Monday, September 21st, 2009 AT 10:49 AM
MOPARMAN 01
  • 17 POSTS
Do a code search it is probley your cam sensor I have a newyorker the same thing happened to my car and that what it was lit me know if that was the problem.
Thursday, November 26th, 2009 AT 10:38 AM
  • 109,885 POSTS
This is a question for you, Moparman. I'm in the process of purchasing a 1994 Stealth. It's nothing fancy, the 3.0L SOHC. THe seller said he was driving it a short distance, heard a ticking sound comming from the lower end of the engine and then the car lost power. I never heard it run, but he says it sounds like it's running on two cylenders. If a rod or main went out, the engine would continue to run until it left go not cause a miss. The only thing I can think of is a head gasket allowed coolant to enter cylenders and perhaps bending a rod.
I've worked on Chryslers all my life, but I never played around too much with the Mitsubishi engines. Have you had any experience with them, if I swap out the intake and exhaust manifolds will any of the 3.0L from one of the Chryslers work or is there something different (which I doubt).
If you have any suggestions or input, I would appreciate it. It is ment to be a project car for me and my son to work on together, but I don't want to get burried in bills for "special" parts only for that car's engine.
THanks.
Thursday, November 26th, 2009 AT 11:50 PM
MOPARMAN 01
  • 17 POSTS
If the Engines look the same anything should enterchange.
Friday, November 27th, 2009 AT 10:23 AM
  • 109,885 POSTS
Just curious about sensors.
Friday, November 27th, 2009 AT 5:23 PM
