Fuel and temperature gauge go max when ignition is switched on
2004 TOYOTA TAZZ
70,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
ALCAPONE1234
Fuel and temp gauge go seem to not be working properly when ignition is switched on.
Sep 12, 2021 at 9:25 PM
SQM
  • 6,383 POSTS
Just to clarify, when you first start the vehicle the temperature gauge and the fuel gauge got all the way to max? Or does it happened when you turn the key to the "on" position?
It does sounds like an issue with the temperature sensor and it is sending wrong signal to the gauge. Please keep in mind this can also be due to faulty gauge.
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
The fuel level reading can also be due to a bad sending unit or the gauge. There is float in the tank with the fuel pump that measures the fuel level and sends that information tot he gauge.
Sep 12, 2021 at 11:23 PM
ALCAPONE1234
Good Evening. When I turn the ignition on both gauges go to the high position. Apparently this is a common in on the Tazz. There is talk of a "bad" earth! I don't think the issue is with the dashboard cluster. Please advise.
Sep 13, 2021 at 2:44 AM
SQM
  • 6,383 POSTS
So this could be due to a weak or bad ground (earth).
Unfortunately I do not have the wiring schematics for the Tazz, as this was not sold in North America.
However you should be able to check the temperature sensor wiring and see if its getting power and if the sensor has the correct resistance value.
Sep 13, 2021 at 5:22 AM
ALCAPONE1234
Thank you
I will check all wiring and see if that solves the issue.
Sep 14, 2021 at 1:53 AM
SQM
  • 6,383 POSTS
Sounds good. Let me know what you find.
Sep 14, 2021 at 3:16 AM
