Fuel and speedometer
35,255 MILES • 1.4L • 4 CYL • 2WD • MANUAL
DAGAI
  • 9 POSTS
Recently had engine overhauled, after that the petrol gauge function is messed up, moves up and down as you drive and speedometer not working at all. Someone said I must check the earth wiring, but where do I find them in the engine area?
Nov 13, 2017 at 5:54 AM
  • 55,694 POSTS
I would start by checking the fuses. here is a guide and some diagrams to help us get started. The grounds for the system are located in the engine compartment. Make sure you have a ground cable or strap going from the engine to the frame.
Cheers, Ken
Nov 14, 2017 at 3:25 AM
