Car continues to bog down and stall after replacing fuel pump and filter
2002 SATURN SL1
294,000 MILES • 4 CYL • MANUAL
SHELAIN BURGESS
I also cleaned the throttle body and sensor and the most of the other sensors and still having trouble. it will run fine when it's not moving but once I step on the gas it bogs down and shuts off.
Oct 22, 2019 at 6:46 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a few different problems. There are several sub systems of your vehicle's engine that can cause this condition as well as internal engine problems too. Here is a link to a guide that will walk you through the possible causes of this below:
https://www.2carpros.com/articles/engine-has-low-power-output
Please go through this guide and get back to us with what you find out and we can go from there.
Thanks,
Alex
2CarPros
Oct 22, 2019 at 8:11 AM
