Fuel
94,000 MILES • 7.5L • V8 • 2WD • MANUAL
JOE LANNON
  • 6 POSTS
I bought this truck from a guy that couldn't get it running. It's carburated with fuel pumps in the tanks, if I crank it over and over it starts up and runs for a minute then dies. The bowls fill with fuel it starts up then the bowls run dry and it stops. I put new fuel pumps in and it does the same thing.
Mar 4, 2016 at 12:35 PM
WRENCHTECH
  • 20,760 POSTS
Check two things, the fusible links coming off the starter solenoid and the oil pressure switch. They both control that feed.
The fusible links are special fuse wire that melts when overloaded. Pull on each wire and see if any stretch. If they do they are burnt and have to be replaced Use ONLY FUSE WIRE to repair this, not regular wire.
Mar 4, 2016 at 10:34 PM
JOE LANNON
  • 6 POSTS
Thank you, I will try those things.
Mar 5, 2016 at 1:38 AM
CJ MEDEVAC
  • 11,000 POSTS
WHAT ABOUT THE FUEL FILTER, HAS IT BEEN CHANGED?
THE MEDIC
Mar 6, 2016 at 3:30 AM
JOE LANNON
  • 6 POSTS
I changed the fuel filter already. Still same thing. I'm going to check the oil pressure switch.
Mar 6, 2016 at 5:12 AM
WRENCHTECH
  • 20,760 POSTS
Make sure you check those fusible links too. One of them powers the running relay. The system starts on one relay and runs on a different one.
Mar 6, 2016 at 5:15 AM
JOE LANNON
  • 6 POSTS
I did the test on the oil relay switch and the test showed that it was bad.
Mar 6, 2016 at 7:35 AM
JOE LANNON
  • 6 POSTS
One more time do you think it could be the control module?
Mar 8, 2016 at 8:10 AM
WRENCHTECH
  • 20,760 POSTS
There are no modules in the fuel pump circuit. https://www.2carpros.com/images/external/42306291.jpg.gif
Mar 8, 2016 at 8:20 AM
JOE LANNON
  • 6 POSTS
I am lost.
Mar 8, 2016 at 8:22 AM
WRENCHTECH
  • 20,760 POSTS
You just have to systematically follow the wiring diagram until you find the problem. It's a very basic and simple circuit.
Mar 8, 2016 at 8:24 AM
WRENCHTECH
  • 20,760 POSTS
See if you have power at the end of that diagram, coming out of the Inertia switch. If you do, you can elimate all that and move onto the selector switch. Here is the diagram for that. it's a little more complicated. https://www.2carpros.com/images/external/42306311.jpg.gif
Mar 8, 2016 at 8:30 AM
