Check two things, the fusible links coming off the starter solenoid and the oil pressure switch. They both control that feed.
The fusible links are special fuse wire that melts when overloaded. Pull on each wire and see if any stretch. If they do they are burnt and have to be replaced Use ONLY FUSE WIRE to repair this, not regular wire.
SPONSORED LINKS
Saturday, March 5th, 2016 AT 6:34 AM
