Fuel
235,000 MILES • 1.8L • 4 CYL • FWD • MANUAL
TARIQ SHAH
I just filled up full tank with shell's V power nitro fuel diesel along with diesel system cleaner my car Engine light is on now why?
May 2, 2016 at 9:55 AM
CJ MEDEVAC
  • 11,000 POSTS
WELL'
YOU HAVE ONE LIGHT
ANY OF MANY POSSIBLE REASONS IT IS ON
TAKE THAT PUPPY OVER TO A POPULAR AUTO PARTS STORE
THEY CAN SCAN FOR CODE, USUALLY THIS IS A FREE SERVICE
HAVE PEN AND PAPER HANDY
YOU WANNA GET THE EXACT CODE NUMBERS, THERE MAY BE MORE THAN ONE (NOT WHAT THEY SAY THEY MEAN/ OR IS WRONG)
THEY MAY BE DEAD ON, BUT IF YOU WANT SOMEONE ELSE TO INTERPRET THEM, THE CODE NUMBERS ARE NEEDED.
EXAMPLE OF A CODE MIGHT BE "P0105" (JUST AN EXAMPLE)
THE CODE WILL BE WHAT THE COMPUTER PICKED UP AS A FAULT, SOME ARE EZ FIXES, OTHERS ARE NOT, BUT ABOVE ALL, THE COMPUTER WILL NOT TELL YOU WHAT TO DO OR CHANGE OUT. ONLY "WHAT HAPPENED" AS A RESULT OF THE GLITCH. THE CODE MUST BE INTERPRETED SO THE PROPER SOLUTION CAN BE FOUND.
RETURN WITH GOOD NEWS OR THE CODES!
THE MEDIC
May 2, 2016 at 10:48 AM
