Engine will not start up and run?
200,000 MILES • 2WD • AUTOMATIC
CHRISKNEELAND
Fuel pump pumps through filter, car turns over with good spark but will not start. Definitely fuel not getting to engine.
Dec 2, 2018 at 5:13 AM
MOTOR MASTER
  • 279 POSTS
Hi, my name is Dave,
Assuming that fuel delivery is your issue it sounds like you are not getting either power or signal to your injectors. The easiest way to test this is with a noid light, you should be able to buy a set for under $20.00. They are very simple to use you simply unplug an injector, plug in the noid light in its place, have someone turn the engine over and see if the light flashes. If the light does not flash the first thing to check would be for power to the injector, a simple test light will work to test for this. Simply turn the ignition on and see if you have power to the injector plug. If you do not check your fuses. If you do and the light still does not flash then most likely your issue is the crank sensor. If the light flashes then you have another issue. The other possibility is that it is not getting enough fuel pressure, the two most common causes of this other than a faulty fuel pump would be the pressure regulator and the fuel filter. I know you said that the fuel comes out of the filter when you cycle the key however that does not mean that there is enough pressure, your car requires 38-44 lbs of fuel pressure. You can get a pressure gauge through most loner tool programs at most auto parts stores. Your car does not have a test port so you would connect it where the fuel filter goes, I would suggest checking it both with and without the filter just to eliminate the filter. If both of these tests come out to be okay then you most likely have a fuel pressure regulator issue.
When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
I hope this has been helpful, let us know if you need anymore help and thank you for using 2CarPros.
Dec 2, 2018 at 7:20 PM
RENEE L
  • 1,260 POSTS
Hello CHRISKNEELAND,
Thank you for visiting 2CarPros. Here is a link to an article from this site with step by step instructions and pictures explaining the process of checking the fuel system pressure, regulator and fuel pump in less than fifteen minutes:
If you need further assistance please come back to the site we are always happy to help.
Kindest regards,
Renee
Admin
Dec 3, 2018 at 3:24 AM
ED TENNYSON
i Have a 1997 Toyota Celica w/2.2 engine.I am experiencing problems with it cranking but not sustaining idle or running.The code pulls up as anopen/short circuit in the igniter system.Prev.repair reccomedations had me change the idle/air cont.valve,the dist.cap/rotor and plug wires and the igniter ohms out good versus a new one.Is it more likely the distributor,the ign,coil or the TPS breaking down or something else altogether?
Dec 29, 2020 at 1:16 AM (Merged)
  • 75,988 POSTS
--Check the EGR and PCV valves, MAF and TPS sensors-
Dec 29, 2020 at 1:17 AM (Merged)
ED TENNYSON
Rasmataz,The EGR as well as the VSV have been changed already.The PCV is fairly new.The MAF,TPS,Ign.Coil and Igniter tested good as of Tuesday 7/12/11.The code that continually comes up as I said is calling a short or open circuit in the Igniter.Any other clues?
  • 75,988 POSTS
Check and test the distributor magnetic pick-up coil
DAKOTA.FOWLER
  • 5 POSTS
Car listed above is the GT model. Last month an aftermarket alarm system stopped working and ruined my ignition. I removed the system and had to splice the ignition wiring back together. The car ran great. A few days ago, while driving, I turned the A/C on and almost immediately it died at a stoplight. I turned the A/C off and it struggled to start. Finally I was able to pull through the stoplight and the car stalled and shut off. It hasn’t been able to start since. I replaced the battery and fuel pump and it still won’t start. I pulled a stored code for it that says “igniter circuit malfunction no. 1”. I’m at a loss if this is a code from a previous problem or if I have an electrical issue. Also; for what it’s worth, the car will start with 50% ether, but shuts off shortly after. There’s a literal laundry list of problems running through my head and any advice is more than welcomed.
  • 110,251 POSTS
The idea that it starts with starting fluid is usually an indication of a fuel issue. As far as the igniter code, what specific code was retrieved? That is specific to the ignition system and can also cause a no start.
With that, I would start by confirming if there is ignition spark to the plugs and confirm the fuel injectors are getting power.
Here are two links that explain how to test that:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Do that and let me know the results. Also, please provide the specific diagnostic trouble code you found.
DAKOTA.FOWLER
  • 5 POSTS
Joe, thanks for the reply and info. The code reader I have didn’t give a specific code number. It said on the screen “igniter circuit malfunction no. 1” after it had me choose the make and model of vehicle. I unhooked the battery and had couldn’t work on the car for a few days and when I came back this morning there were no codes stored. I’m going to let it sit for a while and see if it recovers anything.
DAKOTA.FOWLER
  • 5 POSTS
Update: I tried updating the comments but it’s not saving. The code reader says P1300. I’m on my way to the part store to grab a test light.
DAKOTA.FOWLER
  • 5 POSTS
Update: I picked up the test light. Tested cylinders number 1 and 2 and got no light when my wife tried to start it. This is what I tested.
  • 110,251 POSTS
The code indicates no IGF signal to the ECM. Basically, there is no spark. The IGF signal is communicated with the ECM to indicate a spark has occurred. We have one of two problems. Either we are not getting a signal from the ECM to the coil to create a spark or the coil is bad.
I see the pic above is the spark plug wire. How did you test that?
The way this needs checked is this. We need to determine if there is a signal to the coil and a response back via the IGF signal. I attached a pic below. At the coil, disconnect the electrical connector You will need a multi meter to test for power. Also, the power will only exist when the engine is being cranked and will not be constant. It will power on and off.
Okay, at the connector, there is a white wire (IGT) that sends signal to the coil to fire. There is a blue wire with a yellow tracer that returns signal to the ECM indicating there was spark.
Test one at a time. It will not be more than 5v, but you should see a signal as you have a helper crank the engine. You will need to back probe the wires because they need to be connected on the coil when testing.
If there is signal from the white wire, replace the coil. If there is no signal, we need to work back to the ECM to see if there is an open circuit or a connection issue.
Since you said it starts somewhat with starting fluid, I have a feeling the coil is bad and not producing a strong enough spark to burn fuel. However, this is the only way I know to confirm.
Let me know what you find.
DAKOTA.FOWLER
  • 5 POSTS
Joe, sorry for the delay in replies. There are no individual coils for each cylinder so I couldn’t test the number one. I bit the bullet and replaced the one ignition coil. It was located under the igniter. Tried to start it again today and no luck.
  • 110,251 POSTS
I have a feeling it is a bad connection between the igniter and the ECM. Have you tried checking for the signals I mentioned above? I realize it's not the easiest test, but that is what we need to do.
BERENYI
PulsePulor used motor have good compression have no spark or injection Pulse has fuel pressure.installed a brand new distributor cap and rotor plugs and wires
DOCHAGERTY
  • 9,606 POSTS
Fuel injection strategy requires a reference signal and an RPM signal to activate injectors and to create spark, checking these basics is where I would begin
CHICO12CHICO
I have a celica 1.8 efi. I was driving I came to a stop sign then the car turned off I try to start it but it only cranked it would not turn on the alternator is new and so is the starter. Ihad to have it towed and it still won't turn on. Everything in the car has been working fine till now. Please give me some ideas.
Dec 29, 2020 at 1:18 AM (Merged)
  • 31,937 POSTS
Hi there,
Thank you for the donation,
First thing to do is check for any unresolved fault codes (not all faults will trip the check light) check for spark, injection pulse and fuel pressure, if you can do this and let me know the results it will be a big help in further diagnosing this problem.
mark (mhpautos)
  • 75,988 POSTS
Its crankiing over and will not start do below to determine if its fuel or spark problem.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
VACAD05
  • 5 POSTS
Sputters and cuts off /stalls. It will not start up immediately but wait 10 minutes and it will restart. How to correct stalling?
My 1994 celica GT liftback is a 5 speed manual transmission. I have taken it to Toyota to correct the above problem 4 times over the last month. They changed out the distributor. The problem happened again and Toyota put in another distributor. The problem happened again. The computer codes are still indicating the distributor as the problem.
Toyota wanted to test the computer, but was not able to obtain one and told me there was nothing more they could do. They are not able to diagnose the problem to beyond thinking it may be the computer giving incorrect indications. The stalling /cut off problem is intermittent and occurs whether going at high speed (50 MPH) or slow in a parking lot. Any thoughts as to what the problem could be.
Dec 29, 2020 at 1:21 AM (Merged)
SATURNTECH9
  • 30,868 POSTS
Are you loosing spark when its not starting?
KHLOW2008
  • 41,812 POSTS
What was the trouble code retrieved?
VACAD05
  • 5 POSTS
The computer code is 31.
VACAD05
  • 5 POSTS
I do not recall toyota telling me whether it lost spark. After stalling the ca when trying to start the car the car does not crank. Only the dash board lights come on. After sitting for about 10 minutes the car will start up but runs rough.
SATURNTECH9
  • 30,868 POSTS
So do you have a multi meter to do some testing?Have you had the battery tested and made sure the battery cables clean and tight?
Dec 29, 2020 at 1:22 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Code 31 - MAP sensor signal. Is this code new or was there all along?
Was there any other codes previously?
When engine stalled, by does not crank, do you mean the starter does not even click or clicks but does not turn the engine?
VACAD05
  • 5 POSTS
The battery was installed in Jan 2012. At that time the battery cables were cleaned. And they appear to still be on tight.
When the engine stalled the engine does not even click. Nothing happens just the dashboard lights come on. After sitting for 10 minutes or so the car starts up.
KHLOW2008
  • 41,812 POSTS
This is a fault with the starting circuit and not a problem with battery.
It could be a faulty ignition switch, which explains the stalling. Do you have a DVOM or test light to perform testings?
SATURNTECH9
  • 30,868 POSTS
I will let you finsh this one for me Khlow2008
VACAD05
  • 5 POSTS
No, I don't have any tools for testing. What would I be looking for if I borrowed one from someone?
KHLOW2008
  • 41,812 POSTS
You would be looking for a missing power supply or open in the starting circuit. You need at least a testlight or DVOM.
Saturntech9, you running out on me? lol.
SATURNTECH9
  • 30,868 POSTS
Iam on vacation in las vegas right now so it would help me out if you finished this one.I have been trying to do the questions while i have been gone.But i dont get up to my room much where my lap top is.
KHLOW2008
  • 41,812 POSTS
So you decided to go for a different type of table. Enjoy yourself and good luck.
SATURNTECH9
  • 30,868 POSTS
Thanks i dont play table games and i could use some luck lol.
PRECOTIA
The car was running fine and then the spark plugs were changed. The engines was revved up twice and when it idled down it cut off like you turned the key off. The distributer cap and rotary button was changed and still no fire. What could the problem be?
  • 31,937 POSTS
Hi there,
You will have to check a few basic things first so we know what we are looking at.
Check for spark, injection pulse, fuel pressure, cam is rotating. any fault codes set (light may not be on) if you can check these things first and re post that would be a big help.
Mark (mhpautos)
