Runs fine then sputters and cuts off. let it and it will run good then cut off again.
Dec 31, 2017 at 7:13 PM
✓Experienced Mechanic
Good morning.
The most common issue for this failure is the ignition module. You can remove it and have it tested for free at a parts store to verify it has failed.
a crankshaft position sensor is another common failure.
when it stalls, does it start right back up or is it extended crank?
