Engine stalls when transmission is shifted into gear?
100,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
DON THACKER
Acts like it's cold natured. It runs great as long as idling as soon as I put in gear it starts stalling. Running sluggish.
Sep 23, 2022 at 6:26 AM
  • 110,244 POSTS
There is a chance the fuel pressure is low. Have you checked pressure? If not, that should be done.
Here is a link that explains how it is done:
Also, follow the directions in the following link to see if there are any diagnostic trouble codes stored that may point us in the right direction.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Let me know what you find. Additionally, let me know if this only happens when the engine is cold.
Sep 23, 2022 at 3:10 PM
DON THACKER
Doesn't matter how long it's been running it does the same. I bought it recently and don't know much work has been done.
Sep 23, 2022 at 3:40 PM
  • 110,244 POSTS
It could be a few things. Start by checking to see if there are codes stored that may point us in the right direction. It is likely something simple.
Sep 23, 2022 at 4:13 PM
