Change the oil and filter right away to get the gas out of the oil. The most likely cause is a leaking fuel pressure regulator. That will allow gas to be sucked into the vacuum hose, then it will overload the piston rings and wash past them into the oil.
Nov 13, 2017 at 8:38 AM
