Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ranger
Engine
Symptoms
Not Running
Fuel pressure, will not start
1994 FORD RANGER
175,000 MILES
GARY CARP
MEMBER
Put fuel pressure gauge on got 40 lbs of pressure. Still will not start. Press Schrader valve and fuel seeps out very slow.
Sep 15, 2018 at 3:10 AM
Experienced Mechanic
Good afternoon.
What engine?
Sep 15, 2018 at 7:00 AM
GARY CARP
MEMBER
2.3 liter.
Sep 15, 2018 at 7:36 AM
The pressure should be 35-40 lbs. The fact that you have little fuel indicates either your out of fuel or the pump is bad.
You can have pressure with no volume. If that is the case, the fuel pump is the issue.
Sep 15, 2018 at 7:45 AM
GARY CARP
MEMBER
Will fix it. Thank you sir.
Sep 15, 2018 at 7:47 AM
You are welcome.
Always glad to help.
Sep 15, 2018 at 7:53 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
