Fuel pressure, will not start
175,000 MILES
GARY CARP
Put fuel pressure gauge on got 40 lbs of pressure. Still will not start. Press Schrader valve and fuel seeps out very slow.
Sep 15, 2018 at 3:10 AM
Good afternoon.
What engine?
Sep 15, 2018 at 7:00 AM
GARY CARP
2.3 liter.
Sep 15, 2018 at 7:36 AM
The pressure should be 35-40 lbs. The fact that you have little fuel indicates either your out of fuel or the pump is bad.
You can have pressure with no volume. If that is the case, the fuel pump is the issue.
Sep 15, 2018 at 7:45 AM
GARY CARP
Will fix it. Thank you sir.
Sep 15, 2018 at 7:47 AM
You are welcome.
Always glad to help.
Sep 15, 2018 at 7:53 AM
