Crank no start
2002 PONTIAC AZTEK
260,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
JOSEPH BAIR
Car will start with starting fluid but will not run on its own. Just installed a new fuel pump a month ago. It will not even attempt to fire.. just crank.
Oct 4, 2019 at 1:32 PM
  • 110,244 POSTS
Welcome to 2CarPros.
If it starts with starting fluid, then you have a fuel related issue. Have you checked to see if there is pressure to the fuel rail? The new pump may have failed or even a fuse may have blown. Here is a link that shows how to check fuel pressure. Do this first so we know if the pump is the issue or if there is an injection problem.
______________________________
Also, if there is fuel pressure, confirm the injectors are getting power.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Do this first and let me know the results
Oct 4, 2019 at 2:11 PM
