Not getting fuel to my throttle body?
149,000 MILES • 6 CYL • 4WD
MIZZJULIA73
I'm not getting fuel to my throttle body, but if I put gas in the carburetor it starts up and it has spark.
Feb 2, 2023 at 3:19 AM
  • 55,721 POSTS
When you turn the key on without cranking the engine over do you hear the fuel pump in the tank come on for about 5 seconds? If not, it sounds like the fuel pump has gone bad. Here are the instructions on how to change it out and you must drain the gas from the tank first.
This video will show you how:
https://youtu.be/Q5MH2gnyFH0
Here is a video of the job being done:
https://youtu.be/bCcueO4ALxQ
Feb 2, 2023 at 10:11 AM
