Engine hesitates when trying to accelerate
200,000 MILES • 4.5L • 6 CYL • 2WD • AUTOMATIC
EJROSEBROWN
When driving press the gas it hesitates and then it will take off. Thought is was the catalytic converter, but its not.
May 29, 2018 at 3:27 AM
Good afternoon.
It could be fuel related whether a fuel pump or carburetor accelerator pump. It could be ignition timing as well. You need a timing light to verify the timing. The EGR valve could be partially open causing a vacuum leak and causing the hesitation as well. These guides can help us fix it.
https://www.2carpros.com/articles/engine-hesitates
and
Apr 6, 2021 at 5:45 AM
